Posted: 2025-08-26 01:55 AM
In Geo SCADA Expert 2023 November 2024, I can display objects such as equipment and facilities on the map. Currently, I can add objects individually on the map, but all of them appear at the same hierarchy level. But i would like to create a tree (hierarchical) structure on the map as well. For example, my site objects are:
Reservoirs
Wells
Flowmeters
Valves
However, Flowmeters and Valves should ideally be grouped under a main folder called “Equipment.” So the desired structure would be:
Reservoirs
Wells
Equipments
Flowmeters
Valves
The image below shows the current structure I have created on the map.
This image shows the structure I am thinking of creating.
Is it possible to create such a hierarchy? If not, do you have any suggestions for making the map display more organized and easier to navigate?
Posted: 2025-09-04 02:06 AM
Hi. There's no current way to create a hierarchy of layers, areas or queries, they are all flat lists.
Steve
Steve
