ClearSCADA 2017 R3 and Windows 10 Pro
  • Remote Operations
  • ClearSCADA 2017 R3 and Windows 10 Pro
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
RichardWinnipeg
Crewman RichardWinnipeg
Crewman
Posted: ‎2024-10-03 03:03 PM
1186
I am using App.LogOnUser to automatically logon viewx using a script on a mimic. The approach works fine with ClearSCADA 2017 R3 under Windows 7 Professional.
Now, I have to upgrade the OS to Windows 10 Pro, the same function call App.LogOnUser runs into error
"Class not registered".
Any suggestions ?
Richard
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
RichardWinnipeg
Crewman
Posted: ‎2024-10-08 06:37 PM
Thanks everyone for support.
I found a Windows 10 Pro 2019 edition. Likely, it works.
Replies 4
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2024-10-04 03:51 AM
1168
"Class not registered" is a COM error from Windows and scripting is built on COM.
I would suggest repairing the ClearSCADA installation from "Programs and Features" in the Windows Control Panel. It sounds like the Windows upgrade has 'interfered' with the registration of some COM component (which are stored in the Windows registry).
NB. ClearSCADA 2017 R3 went out of support almost 3 years ago.
Andrew Scott, R&D Principal Technologist, AVEVA
RichardWinnipeg
Crewman
Posted: ‎2024-10-04 04:46 AM
In response to AndrewScott
Thanks Andrew.
I have tried re-install numerous times with different versions of windows 10 pro and two different versions of 2017 R3 (2019 and the last revision).
They all had the same problem.
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2024-10-04 06:29 AM
I had assumed you had just done an in-place upgrade to Windows 10. Its very strange you're seeing this across all of those versions and re-installs. The error points to an installation issue as something is missing from the Windows registry.
The error message doesn't make it clear which class is not registered, but logically it would be the ViewX Object Library which provides the "App" object (amongst others).
You could check that the following registry keys are present (including sub-keys). These should be created by the ClearSCADA installer.
"Serck Controls ViewX Object Library" type library:
HKEY_CLASSES_ROOT\WOW6432Node\TypeLib\{EEAD1000-0777-11D2-AF05-0000E82E7A14}
"IViewXScriptApp" interface:
HKEY_CLASSES_ROOT\WOW6432Node\Interface\{59C98D2C-7F90-482F-A915-290383B68715}
You may be better off raising a support ticked with Schneider as this doesn't look like a straightforward issue.
RichardWinnipeg
Crewman
