Invalid Template Expression, Unspecified error
  • Remote Operations
  • Invalid Template Expression, Unspecified error
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
kbedi
Crewman kbedi
Crewman
Posted: ‎2024-10-02 12:16 PM
1127
I am getting an unspecified error on some objects. Any ideas what this error means or what could be causing it?
Invalid Template Expression evaluated. Object "xxx" Field "Double", Unspecified error.
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-10-08 12:29 AM
I suggest you contact Support with a reproducible example.
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2024-10-03 06:56 AM
The error message indicates that this parameter object is in a group template, or an instance of a template, and there is an expression property override on the "Double" field of this parameter object in the template.
The evaluation of this expression is failing, but "unspecified error" does give much clue as to the specific problem.
If you can share the expression that you've configured for this field then we may be able to determine what the issue is with the expression.
Andrew Scott, R&D Principal Technologist, AVEVA
kbedi
Crewman kbedi
Crewman
Posted: ‎2024-10-04 10:18 AM
Thanks for the reply. I was having this issue when I created my object using an import and the object would reference a template in the server. Instead when I created the object instance from scratch using the same template, the error went away. Something happened when I imported the object causing that error.
sbeadle
Kirk sbeadle Kirk
Kirk
