Posted: 2023-04-12 08:09 AM . Last Modified: 2023-05-02 11:45 PM
When I create a text box in any mimic in Geo SCADA Expert 2021, I can assign any signal from the "Animations-Value" screen and this feature works without any problems. For example, in this image, I can write the WLM_ID value of the signal in the text box I created, and when I change the WLM_ID, the text box also changes.
But what I need is the opposite of that. When I change the value in the text box, I want the WLM_ID in the Identification tab in the signal to be changed. Is this possible?
Posted: 2023-04-12 08:21 AM
You would need to add a script pick action to the text box in the mimic.
The script itself will need to display a form to prompt the user to enter the new value and then write that value to the database field (WLM_ID) of the required database object.
See Mimic Scripts in the help for details.
