Calculate Average Data and Get Minimum Values
  • Remote Operations
  • Calculate Average Data and Get Minimum Values
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
abdullah123456789
Lt. Commander abdullah123456789
Lt. Commander
Posted: ‎2023-02-08 10:24 PM . Last Modified: ‎2023-05-02 11:48 PM
2319
I'm receiving datas in Geo SCADA. This datas are real time datas and saved to the database every 5 minutes as in the image below.
I need to take the average of this data recorded every 5 minutes and save it to the database hourly. Can I do this using the "calculation" feature? I did some things, but it recorded the average values in 5 minutes, not hourly. Did I make a wrong setting or is it not possible to calculate from here?
A second issue is that if I can save these data to the database hourly, I need to automatically select and specify the minimum 2 or 3 values in the next 24 data per day and create a trend list and specify these values in this trend. Is something like this possible? If possible how can I do it? Can you help me?
  • SCADA
  • Trends
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 5
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2023-02-09 02:05 AM
2306
Your calculated point is updated on change of the input, so if the input changes every 5 minutes the output is calculated at that interval too - it will be a rolling hourly average.
Choose the Trigger Condition to be Periodic instead and set the interval to 1H, offset H
Alternatively use an Accumulator point, type 'Mean' and set it to report and reset hourly.
Accumulator points also have a 'Minimum' type which may solve your second question.
abdullah123456789
Lt. Commander
Posted: ‎2023-02-09 03:09 AM
In response to sbeadle
I tried to pull the minimum or maximum data using the accumulator as you said, but I couldn't find any option to show more than one value in the trend. Can you help a little more with this? In addition, the data I received per hour from the maximum and minimum accumuators I created are as follows. I did not fully understand this data. Can you explain?
"Historic List" pages with a maximum on the top and a minimum on the bottom. Why are the values at the maximum and minimum the same here? Also, what is meant by the data coming in as current data?
abdullah123456789
Lt. Commander
Posted: ‎2023-02-15 10:22 PM
Thanks for the first topic. I can get the values as I want. But I'm still having problems with showing at least 3 values in the trend from the last 24 hours. I couldn't find anything on the help page either. Is there any solution to this situation?
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2023-02-17 04:13 AM
2245
What do you mean, top/bottom 3 values per day?
abdullah123456789
Lt. Commander
Posted: ‎2023-02-20 01:22 AM
I get data from RTU regularly and this data should be calculated hourly average and saved in the database hourly. For example, I have to calculate the value between 2-3 pm and save it to the database as the average value of 2 o'clock. I did this by making the following settings on the Calculation Tag. But when the settings are like this, the data is 2-5 A.M. It causes more than one value to be saved in the range. Actually, this is my first problem. I'm attaching a few screenshots of this situation below. The two above are images of the settings, and the one below is the Historic List image.
Thanks to the Historic List I created in this way, I was able to have a trend page. However, there was a problem with the trend. The hourly data in the trend list of the signal I created does not match the Historic List. Below I share the trend I created and some of the data in the trend with the images I marked with Ruler. I have already shared the Historic List of the same signal, belonging to the same days and times, above.
The other problem I'm having is as follows. That's what I really needed to learn. When I save this signal to the Historic List and view the trend page, I need to show only these minimum 3 data on the trend by first ordering the 24 data of a day I recorded on an hourly basis from the smallest to the largest, then filtering the data in the first 3 rows (minimum 3 data). I guess we could call it trend filtering.
These hourly data that I saved to the database are a total of 24 daily in the "historic list". I need to sort these 24 data from the smallest to the largest and then mark or specify the 3 data with the smallest value on the trend page I created. So in summary, I'm going to create a daily trend with the x-axis hourly. These values on the x-axis will include 0-23. There will be data every hour. The minimum of 3 values in this hourly data, which is shown in the trend, will be prominently displayed among other values. (a distinctive shape means circling, drawing those values in different colors, creating a text box over the points where the minimum values are)
I showed what I'm talking about by marking a minimum of 3 values in the image below.
