Automated Report Generation
Select a Country
  • Remote Operations
  • Automated Report Generation
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
KylePaynter1
KylePaynter1
Explorer
Posted: ‎2020-03-13 05:09 AM . Last Modified: ‎2023-05-03 12:16 AM
4723
Hi Community
I'm trying to determine how to automate a current and working Query that does diagnostic on our RTUs to daily generate and export that list at a particular time everyday.
Thanks for your assistance guys
  • scada
Hardin4019
Hardin4019
Troubleshooter
Posted: ‎2020-03-13 08:37 AM
5
4715
In the DataBase Tree, right click, then Create New > Other > Schedule.
Put your Query into a "SQL Export". Setup the Schedule to run Daily, weekly, or Monthly, etc, choose the time. Then drag and drop the SQL Export into the Object portion at the bottom of the Schedule window and choose "Export SQL Query Result" as the method.
AndrewScott
AndrewScott
Leader
Posted: ‎2020-03-13 08:53 AM
In response to Hardin4019
An alternative to an "SQL Export" would be a Crystal Report. This gives you more choices over the generated file format, e.g. Word, Excel, PDF, rather than just CSV.
Andrew Scott, R&D Principal Technologist, AVEVA
Replies 6
Hardin4019
Hardin4019
Troubleshooter
5
4716
AndrewScott
AndrewScott
Leader
Posted: ‎2020-03-16 04:48 AM
4668
Thank you very much for taking time and effort to respond.
I will look into this
Tdog
Posted: ‎2020-03-19 02:15 AM
In response to Anonymous user
I've marked Hardin4019's post as the solution, feel free to do so yourself if you are happy with an answer in future.
bigdaz
bigdaz
Contributor
Posted: ‎2020-04-30 12:10 PM
4450
Hi Would anyone have an example script of how to do this?
Hardin4019
Hardin4019
Troubleshooter
Posted: ‎2020-05-01 05:45 AM . Last Modified: ‎2023-04-25 03:49 AM
In response to bigdaz
Not much of a need to use a script since most of what you would need to run a report can be accomplished with a schedule. But, I suppose if you wanted to, the biggest thing you would need to know is how declare and call a Method to Execute or Export a SQL Export or a Crystal Report.
Here is a link that might have helpful info.  https://community.se.com/t5/Geo-SCADA-Knowledge-Base/SMS-Alarm-Redirection/ba-p/278225
