Cloud connection Issue
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • Cloud connection Issue
Thierry_Baudard
Commander Thierry_Baudard Commander
8
EduardoFainblum
Commander EduardoFainblum Commander
6
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
Back to EcoStruxure Energy Hub
WestwoodsAutomation
Crewman WestwoodsAutomation
Crewman
Posted: ‎2025-10-24 03:16 AM
341
Hi guys
We have successfully installed 8 PAS600s onsite and only have a few more.
We have hit a snag with the latest one however.
We cannot get the Schneider Cloud service to connect. It just says 'connection in progress' with the spinning green circle. The difference with this specific install over the other successful install is we are using a 4g modem connection - Teltonika RUT241. The PAS600 is set as DHCP and has received its network settings from the modem. We have connected to the Teltonika LAN network and confrimed we can reach the WWW. Thinking it may be a port issue, I changed the default firewall settings to allow all incoming connections (IT pros will have a conniption at that comment 🤣). Have restarted both the PA600 & the modem but still cannot get a successful cloud connect.
Any suggestions?
The Connection diagnostics  states 'Network configuration error or device not registered.' (see pic attached)
Not sure what the 'not registered' part means and if that is something we need to do?
  • Knowledge Base
Thierry_Baudard
Commander
Posted: ‎2025-10-24 05:52 AM
336
Hi @WestwoodsAutomation,
1)  Teltonika must deliver at least one DNS address to the Panel Server.
Can you please check if there is a value configured  in the Panel Server ?
2) Panel used the 7 urls herunder  to connect  to SE Cloud  (screenshot hereunder extracted from EcoStruxure™ Energy Hub - IT and Security Guide | Schneider Electric .)
Can you please check if these url are allowed/not blocked in the Teltonica Router .
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
WestwoodsAutomation
Crewman
Posted: ‎2025-10-24 02:19 PM
In response to Thierry_Baudard
Thankyou Thierry
i will check on the above. I did create a rule to allow all traffic but will try the specific rules too.
regrading point 1, the panel server is set to dhcp and  I did notice that in the DNS tab of the panel server, the first entry was 192.168.1.1 (which is the gateway of the Teltonika). Is this normal? Or should teltonika tell panel server fo eg. 8.8.8.8 or 1.1.1.1 ?
Thankyou for your help
Thierry_Baudard
Commander
Posted: ‎2025-11-06 07:35 AM
Honestly, I'm not an expert on the Teltonica router, so it's difficult for me to tell you if the address sent via DHCP by the Teltonica to configure the DNS for the panel server is correct or not.
What I can suggest is:
Test 1: Select "Static" mode for the DNS address on the Panel Server and try with 8.8.8.8 (Google DNS) then retry.
Test 2: Perform a factory reset of the Teltonica router, then upgrade it to the latest available firmware before retesting.
BR
Thierry BAUDARD
