Other numeric thresholds
DCE alarm configuration
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • Other numeric thresholds
  • Mark as Read
  • Numeric alert thresholds
  • Managing a remote user
  • Creating alarm notifications
  • Alarm configuration display search field
  • Alarm Configuration Overview
EcoStruxure IT Support
Request Support
Back to DCE alarm configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Set thresholds for numeric sensors that monitor values not covered by the nine threshold-specific numeric options.
The following lists identify some common examples of numeric sensors you can configure using the Other Numeric Sensors option. The actual sensors will depend on the device types managed by the Data Center Expert server.
Note: You can configure multiple sensors discovered for the Other Numeric Sensors option, when the sensors you select can all use the same threshold settings. For example, battery and UPS age sensors, can be configured to use the same thresholds, as can utility, input, and output voltage sensors.
UPS Battery Sensors:
  • Battery Age
  • Battery Runtime Remaining
  • Battery Capacity Remaining
  • Time Running on Battery
Other UPS Sensors:
  • UPS Age
  • Input Frequency
  • Output Frequency
  • Output Load
  • Output Power Percent VA
Other Sensors:
  • Max Number of Output Relays
  • Max Number of Input Contacts
  • Runhours of Fan
  • Air Flowrate of Fan (in cfm)
  • Total Air Flow (in cfm)
  • RPM Speed of Fan
