"MMC Could not create the swap-in" Error when installing SQL 2008 Express with I/NET 2.42
  • "MMC Could not create the swap-in" Error when installing SQL 2008 Express with I/NET 2.42
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-10 11:36 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:02 PM
TAC INET
  • SQL 2008 Express 32-bit
  • Windows 7
SQL requires certain aspects of windows to be in place before installation. Ensure you have installed all windows updates available before installing SQL 2008 Express 32 bit
  1. Uninstall I/NET and SQL
  2. Remove SQL items from the windows registry. (See Verify in Windows Registry all items are deleted after uninstall of I/NET Seven and MS SQL)
  3. Use Windows update to install all available Windows updates
  4. Re-install SQL
  5. Re-install I/NET 2.42
  • TAC INET
  • 8165
