"Clear when enabled" does not cause the trend log data to be cleared
  • "Clear when enabled" does not cause the trend log data to be cleared
‎2018-09-10 12:57 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:37 AM
Even though "Clear when enabled" is configured on a trend log, the trend data is not cleared when the log activation is triggered.
  • Enterprise Server
  • Automation Server
  • Trend Logs
Warning
The property "Clear when enabled" only affects the trend data when the trend log goes from disabled to enabled.
This is not the same as the activation method of the trend log. Activation method changes the Status from Stopped to Started etc.
To activate the "Clear when enabled" setting configured on the trend log:
  1. Select the Trend log, right-click on it and select Activation, then select "Disable trend log".
  2. Select the Trend log, right-click on it and select Activation, then select "Enable trend log".
See the following online help topics for further information on Activation:
  • Trend Log Activation
  • Actions Menu - Activation Submenu
Tags (2)
  • 18861
  • PeterEdvik19
