Xenta 102-AX temperature sensors reading incorrectly, very high
  • Xenta 102-AX temperature sensors reading incorrectly, very high
  • SESA150559
    SESA150559
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
‎2018-09-10 03:34 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:52 AM
  • Xenta 102-AX temperature sensors reading in the range of 130°F (54.4°C) when they should be closer to room temperature. Wiring has been checked and everything appears correct.
  • What kind of temp sensor do I use for a 102-AX?
EcoStruxure Building Operation, TAC Vista
  • Xenta 102-AX
  • ETD-1xx duct temperature sensors
  • ETR-1xx room temperature sensors
  • STR-1xx room thermostats
Every other Xenta controller uses a 1.8k-ohm thermistor as a standard. Because the Xenta 102-AX is a modified version of the I/NET MR-VAV-AX, it still uses the 10k-ohm thermistors native to the I/NET product line.
The Xenta 102-AX uses 10k-ohm thermistors. See 10k Thermistor compatibility with Xenta controllers for detailed information on the thermistor curve that is acceptable. Approved sensors are:
  • ETD-2xx duct temperature sensors
  • ETR-2xx room temperature sensors
  • STR-2xx room thermostats
  • STD-2xx duct temperature sensors
Labels (2)
Tags (3)
  • 5921
  • compatibility
  • kohm
