Workstation error when logging into a remote Enterprise Server 'No valid client license available. (Error -5: No such feature exists.)'
  • Workstation error when logging into a remote Enterprise Server 'No valid client license available. (Error -5: No such feature...
  • RandyDavis
    RandyDavis
  • RyanSuar
    RyanSuar
  • Katha
    Katha
Admiral RyanSuar Admiral
‎2019-09-16 08:38 AM
Last Updated: Lt. Commander Katha Lt. Commander ‎2025-10-15 03:08 AM
When attempting to log into a remote Enterprise Server using EcoStruxure Building Operation WorkStation, the following error is displayed:
“No valid client license available. (Error -5: No such feature exists.)”
This occurs despite the Enterprise Server having available client licenses
  • EcoStruxure Building Workstation
  • EcoStruxure Building Operation License Administrator
The WorkStation application is attempting to acquire a client license from the local machine’s default license server address (@localhost). However, the active license is hosted on the Enterprise Server, which is configured as the central license server. Since no license is available locally, the request fails with error code -5.
To redirect the license request to the correct server:
  1. Launch License Administrator
    On the WorkStation client machine, open the License Administrator utility.
  2. Modify License Server Address
    • Navigate to the License Server Address field.
    • Replace the default value @localhost with the IP address or hostname of the Enterprise Server hosting the license.
    Example:
    To: 192.168.1.100
  3. Apply and Restart
    Save the configuration and restart WorkStation to apply the new license server settings.
Notes:
  • Ensure network connectivity between the WorkStation client and the Enterprise Server.
  • The Enterprise Server must have the License Server service running and properly configured.
  • Refer to the WebHelp documentation for detailed steps on configuring license server addresses  License Server Address
Tags (2)
  • KatharineVasquez25
  • RyanSuar19
67% helpful (6/9)
