When trying to install TAC Vista, the only available option in the wizard is to uninstall it
  • When trying to install TAC Vista, the only available option in the wizard is to uninstall it
  • RobertAndriolo
    RobertAndriolo
  • Jonas_Brissman
    Jonas_Brissman
  • sesa119747
    sesa119747
‎2018-09-06 02:39 PM
Last Updated: Picard RobertAndriolo Picard ‎2019-06-17 07:43 PM
When trying to install TAC Vista and running the installation file the only option available in the installation wizard is to uninstall TAC Vista.
TAC Vista
Vista server
A registry key which is not taken away when uninstalling TAC Vista is indicating to the installer that Vista is already installed.
NOTE: Serious problems can occur if you modify the registry incorrectly. Make sure that you follow these steps careful.
  1. Open the Registry: go to Start > Run and type "regedit"
  2. Remove the folder for TAC Vista Server under:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
    The Vista folder will contain "TAC Vista Server" in the "Display Name" field and can be found by selecting each folder.
Tags (2)
  • 3358
  • JonasBrissman19
