What substitution codes are available to embed data into alarm text?
  • What substitution codes are available to embed data into alarm text?
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
  • CraigEl
    CraigEl
‎2018-09-06 10:36 AM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2023-08-21 04:50 AM
How can I insert the points name or path into the alarm text?
  • Building Operation Enterprise Central
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server
  • Building Operation WorkStation
Require dynamic text insertion in the alarm text.
The following substitution codes exist for alarm messages:
All SBO/EBO versions:
 @(F) – The path of the monitored variable.
 @(O) – The monitored object name.
 @(P) – The monitored variable.
In addition to the above, Version 1.2 also includes:
@(V) - Displays the value of the monitored variable at the time of the state change.
e.g. If you create an alarm that is monitoring a temperature object named Room1Temp and write an alarm message that says: “The point @(O) is too hot.” When the alarm is triggered it will display:
“The point Room1Temp is too hot.”
Refer to: Alarm Messages
Tags (2)
  • 12664
  • MahmoudSayed23
