Continue
  • My Subscriptions
  • Events
What is the maximum number of nodes and points allowed while using a Modbus TCP/IP or RTU xdriver on a BCX?
  • What is the maximum number of nodes and points allowed while using a Modbus TCP/IP or RTU xdriver on a BCX?
  • MaximeLaudren
    MaximeLaudren
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
  • Carl_Slack
    Carl_Slack
‎2018-09-07 04:11 AM
Last Updated: CraigEl Champion ‎2022-08-19 12:30 AM
Definition of number of nodes and points allowed using Modbus TCP/IP or RTU xdriver.
Andover Continuum
Modbus Protocol
Definition of number of nodes and points allowed using Modbus TCP/IP or RTU xdriver according to the modbus protocol.
The maximum number of nodes is 254.
The address range for points is 1 through to 65535. The number of addresses is limited by the controller memory. We have had ~6000 points but please note the Modbus is a polled protocol so the more points you have the longer the poll rate.
Specific Modbus RTU Details
Our Modbus RTU XDriver supports the node range from 0-255. According to the Modbus specification, the node range is from 0 – 255, with 0 being the master, 1-247 being the slaves, and 248-255 being reserved addresses.
After 32 nodes (1 master + 31 slaves), you may need RS-485 repeaters to ensure proper communications. This depends on a number of different items, including if the RS485 transceivers are full or quarter load.
You can find the Modbus serial standard at the link below for further details.
http://www.modbus.org/docs/Modbus_over_serial_line_V1.pdf
Tags (5)
  • 4016
  • amount
  • how
  • many
  • MaximeLaudren22
