What is the accuracy of Real Time Clock?
  • What is the accuracy of Real Time Clock?
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
‎2018-09-11 04:50 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:18 AM
What is the accuracy of RTC?
Andover Continuum
Site with controllers using the RTC Crystal Quartz chip (controllers such as the ACX)
When the controller is powered down, the battery-backed RTC Chip has an accuracy of +/- 1 minute per month. When powered on, the controllers use the RTC chip as a reference point but keep time in software. Experience has shown an accuracy of 1 – 2 seconds per month when controllers are offline and not re-synched from the Network. Since that is typical and not calculated, a conservative number would be +/- 10 seconds per month. When Online,the accuracy is determined by Cyberstation which can itself be synched to an extremely accurate NST Server. I2 and B3 controllers are re-synched once per hour.
For Sync time in Cyberstation(s) and Server check Sync time in Cyberstation and Server.
For more information see What are the differences between a hardware and a software Real Time Clocks (RTC)?.
For how field controllers keep their own internal time check How do our field controllers keep their own internal time?
  • 13544
