What are the Output ratings on a Digital Output for B3-920
  • What are the Output ratings on a Digital Output for B3-920
  • Alan_Wood
    Alan_Wood
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:16 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 02:31 AM
What are the output ratings for the digital outputs on the B3-920 controller?
Andover Continuum
B3-920 controller
Clarification needed on the electrical specifications and configuration options for the B3-920 digital outputs.
The B3-920 controller includes:
  • 8 Digital Outputs
    Each output is a Single Pole Single Throw (SPST) Form C relay.
  • Configurable Output Option
    Any two consecutive Form C outputs can be configured as one Form K Tri-state output.
  • Electrical Ratings
    • Maximum Current: 3A
    • Voltage: 24VAC/VDC
    • Transient Protection: ±1500V (Tested according to EN61000-4-4 standard)
Tags (2)
  • 4341
  • AlanWood25
