WebReports returns only partial results for the Meter report
  • WebReports returns only partial results for the Meter report
  • LocNguyen
    LocNguyen
  • RobertAndriolo
    RobertAndriolo
  • JonGreen
    JonGreen
Lieutenant JG LocNguyen Lieutenant JG
‎2023-05-25 04:13 PM
on ‎2023-05-25 04:13 PM
WebReports returns only partial results for the Consumption Report when using the Meter Utility Type
  • Building Operation Report Server
  • Building Operation WebReports
This is a limitation of the Meter report, where the report returns approximately 50 Meter reports at a time regardless of how many meters are selected.
It is recommended that 30 - 40 meters at most be selected at a time for this report.  Selecting more meters for the report may result in data overlap and unexpected output.
For more information regarding Consumption Reports, see the following help topic Energy Monitoring Reports
  • RobertAndriolo23
