Vista trend logs are blank
  • Vista trend logs are blank
  • Jonas_Brissman
    Jonas_Brissman
  • Cody_Failinger
    Cody_Failinger
‎2018-09-07 07:12 AM
Last Updated: Janeway Jonas_Brissman Janeway ‎2024-08-22 01:47 AM
When a trend log is opened up from Vista Workstation, there are no values or information in them. The trend logs are empty.
TAC Vista
Vista Server
The computer or user permissions do not allow Vista to create new directories.
Check the $queues folder in the Vista database. If the $queues does not have the insertevents and insertlogvalues folders underneath it then create these folders manually. Now check the trend logs in Vista Workstation again, all of the trend logs should show up.
Tags (2)
  • 14128
  • JonasBrissman24
