Vista license path is not held and needs to be entered each time you start Vista
  • Vista license path is not held and needs to be entered each time you start Vista
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
‎2018-09-10 11:10 PM
When you start Vista workstation that is receiving an license to run from another PC the path to this PC is lost each time Vista workstation is shut down.
Window 7
Server 2008
The User Account Control Setting is set too high preventing the license path being saved.
Drop the user account control setting level down to allow the license server path to be saved.
From the Windows Start menu option type "User Account Control settings" in the "Search programs and files"
Then decrease the security level.
  • 12040
