Viconics - How does the Occupation Sequence of a SE7200 controller operate.
  • Viconics - How does the Occupation Sequence of a SE7200 controller operate.
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-10 11:23 PM
How do the controller settings affect the Occupation Sequence in respect of temperature control.
Stand alone.
Part of a system.
Customer is uncertain of how this process works, the rooms are cold.
There are a number of settings that will affect this sequence, the screen shot below shows the sequence and the settings used.
Labels (5)
  • EcoStruxure Building Expert
  • Field Devices
  • 12216
