VBOX_E_INVALID_OBJECT_STATE error when attempting to install Server Packs on New PCT Installation
  • VBOX_E_INVALID_OBJECT_STATE error when attempting to install Server Packs on New PCT Installation
  • RandyDavis
    RandyDavis
  • JohnBoehmer
    JohnBoehmer
  • CraigEl
    CraigEl
JohnBoehmer Schneider Alumni (Retired)
‎2021-02-10 01:47 PM
Last Updated: Administrator CraigEl Administrator ‎2023-07-12 06:47 PM
The ServerPack installation process does fail to complete on a new PCT installation
PCT presents the following error.
: 'beee::vm_module::VirtualBox::make_disk_multiattach' due to: 'VBoxManage.exe: error: Cannot change the type of medium 'C:\ProgramData\Schneider Electric EcoStruxure\Building Operation\Project Configuration Tool\external\VM\docker.vmdk' because it is attached to 1 virtual machines
VBoxManage.exe: error: Details: code VBOX_E_INVALID_OBJECT_STATE (0x80bb0007), component MediumWrap, interface IMedium, callee IUnknown
Building Operation Project Configuration Tool (PCT)
The VBoxHardening.Log (\\Users\John Boehmer\VirtualBox VMs\NoteTEst\Logs) is flagging dll flags that are incorrectly signed.
supR3HardenedScreenImage/Imports: cache hit (VINF_SUCCESS) on \Device\HarddiskVolume3\Program Files\Oracle\VirtualBox\Qt5CoreVBox.dll [lacks WinVerifyTrust]
If an attempt is made to create a virtual instance in VBox the machine fails to run with the following error.
Uninstall all non-essential software applications from the host machine.
In this case, PCT was being installed on a brand new Hewlett Packard PC that had a variety of HP security software.
In some cases, other non-essential applications may need to be uninstalled as well.
Once the software was uninstalled PCT was reinstalled over the top of the existing installation.
Virtual machines created in VBox could then be started and PCT began to function normally.
Labels (2)
  • Project Configuration Tool
Tags (4)
  • JohnBoehmer21
  • Server Packs
  • vbox
  • WinVerifyTrust
75% helpful (3/4)
