Using the MPM as both monitor and coordinator at the same time
  • Using the MPM as both monitor and coordinator at the same time
  • CraigEl
    CraigEl
  • Benji
    Benji
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 08:45 AM
Last Updated: Administrator CraigEl Administrator ‎2023-11-12 04:50 PM
What is the benefit in having separate MPM monitor and coordinator?
EcoStruxure Building Expert
MPM
In smaller networks, it is acceptable to have the monitor function as the coordinator. However, in larger networks, the monitor becomes occupied with managing the traffic of all the remote MPMs, resulting in significant CPU usage. This applies to zigbee, UDP, and CANbus networks. Making the monitor a coordinator does not provide any advantages; it only introduces disadvantages.
In smaller networks, it is acceptable to have the monitor act as the coordinator. However, in larger networks, the monitor's workload increases as it manages the traffic of multiple remote MPMs, consuming a significant amount of CPU resources.
  • EcoStruxure Building Expert
Tags (2)
  • 18128
  • CraigEllis23
