Using the MP-V Hall Effect Sensor object
  • Using the MP-V Hall Effect Sensor object
  • RobertAndriolo
    RobertAndriolo
  • JonGreen
    JonGreen
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2019-02-21 10:57 AM
Last Updated: Picard RobertAndriolo Picard ‎2019-05-30 04:55 AM
Cannot use the Hall Effect Sensor object under the Onboard IO of an MP-X
  • Building Operation Workstation
  • Building Operation Multi-purpose VAV
The object is an internal sensor for measuring the position of the actuator.
The hall Effect Sensor Object is not an user configurable object.
Tags (5)
  • damper position
  • hall effect
  • mp-v
  • mpv
  • StephenYang19
75% helpful (3/4)
