Using multiple tags in Access Expert acts as though there are no tags
  • Using multiple tags in Access Expert acts as though there are no tags
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
Commander JonGreen Commander
‎2021-09-07 12:54 PM
on ‎2021-09-07 12:54 PM
Permissions are set with multiple tags as the following:
When the user logs into Access Expert and looks at the hardware tree, they are able then to see all the hardware on the instance rather than just those with the matching tags.
EcoStruxure Access Expert
  • Access Expert Hosted Software
  • Access Expert Premise Software
The tags are meant to be on separate permissions and shouldn't be used on the same individual permission
Tags and permissions should be set up as illustrated:
  • EcoStruxure Access Expert
  • JonGreen21
