Using multiple monitors with I/NET
  • Using multiple monitors with I/NET
  • Cody_Failinger
    Cody_Failinger
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
  • sesa145087_brid
    sesa145087_brid
‎2018-09-10 05:39 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:58 AM
Drop downs not visible on secondary monitor used with I/NET
TAC INET
  • Windows XP
  • I/NET Seven 2.41
As of 2.41 I/NET is not intended to be a multiple monitor platform
  1. Modify the display settings to configure the monitor with the I/NET display as the primary monitor
  2. Upgrade to I/NET 2.41 using Windows 7 as this problem has not been seen with this specific installation
  3. Use I/NET on your primary monitor and AMT on your secondary monitor.
If it doesn't work, please refer to Drop list of point control in I/NET summary on secondary monitor does not work.
  • TAC INET
  • 6545
