Using a card reader to Unlock and Secure a Building
  • Using a card reader to Unlock and Secure a Building
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-10 03:25 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 06:39 PM
TAC INET
  • I/NET Seven
  • 7798
Site requests the ability to have a user card in at the beginning of the day locking the door and card out at the end of the day unlocking the building
  1. Create and AIC triggered from the card reader to start an event sequence as outlined in Using AIC to trigger an event sequence
  2. The AIC should trigger an event sequence (sequence1)
  3. Line 1 of sequence1 should be skip if 0, looking to see if the door is lock and skipping to sequence2
  4. Line 2 of sequence1 should be skip if non-0, looking to see if the door is unlocked ad skipping to sequence3
  5. Sequence 2 should unlock the door(s)
  6. Sequence 3 should lock the door(s)
You may need to change the delays until you get an acceptable response. Ideally Line 1 of sequence 1 should be delayed long enough for the door to return to lock after the reader entry.
As an option you could have sequence 1 check the status of the door. A badge read when the door is closed unlocks the door(s). A badge read when the door is open locks the door(s).
  • TAC INET
  • 6230
