Using a Sigma DNN (Distributed Network Node) as a repeater
  • Using a Sigma DNN (Distributed Network Node) as a repeater
  • CraigEl
    CraigEl
  • RyanSuar
    RyanSuar
‎2018-09-06 03:58 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 05:33 PM
There is no dedicated repeater available in the Sigma product range to extend the maximum distance of a Sigma ARCnet LAN.
Satchwell BAS & Sigma
Satchwell Sigma ARCNET communications
Sigma does not offer a standalone repeater device. Therefore, alternative methods must be used to extend ARCNET LAN distances beyond standard limitations.
To extend the ARCNET LAN:
  1. Use an additional Sigma DNN on the backbone LAN.
  2. Connect an ARCNET cable from the first DNN (port 1) to a second Sigma DNN (port 6).
  3. Ensure no Sigma controllers are present on the joining LAN segment.
  4. The DNN used must be a dual trunk version to support this configuration.
📌 Note: The maximum cable length depends on the baud rate and cable type used. Refer to the ARCNET distance tables for specific limits.
ARCNET distances
  • Satchwell BAS & Sigma
Tags (2)
  • 7337
  • CraigEllis25
