Using SQL database upgrade without a instance name on the SQL server.
  • Using SQL database upgrade without a instance name on the SQL server.
  • Jonas_Brissman
    Jonas_Brissman
  • PeterLarsen
    PeterLarsen
‎2018-09-10 11:03 PM
Using the SQL database upgrade program for Vista is it possible to connect to a "real" SQL server without a instance name which is installed on the same computer ?
TAC Vista 5.1.7 and later.
TAC Vista SQL Database upgrade.
When specifying the server name the default is .\TACVISTA, the . is the PC name and the TACVISTA is the instance name.
So if the SQL server is installed on the same computer and have no instance name just type .\ on the Server path.
  • 11786
