Users of Continuum not transitioning to Security Expert
  • Users of Continuum not transitioning to Security Expert
  • RandyDavis
    RandyDavis
  • JamesMorgan
    JamesMorgan
  • AdamSteele
    AdamSteele
Lieutenant JG JamesMorgan Lieutenant JG
‎2022-08-03 12:10 PM
Last Updated: Guinan AdamSteele Guinan ‎2024-06-12 10:52 PM
When transitioning users from Continuum to Security Expert, only about half of the user db is transferred.
EcoStruxure Security Expert
  • Security Expert Controller
  • Continuum Database Transition Tool
  • Security Expert Data Sync Service
  • Continuum Database Transition Tool and Security Expert client must BOTH have the same configuration for "Allow Pin duplication". It could be either both unchecked or both checked
  • Export history must be deleted when Continuum Transition Tool and Security Expert Data Sync services have stopped
After a fresh transition and proper configuration ("Allow Pin duplication" in both CTT and SX client):
In the Continuum Database Transition Tool:
  1. Stop both Continuum Database Transition and Security Expert Data Sync services
  2. Delete export history
  3. Start both services again
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele24
  • JamesMorgan22
