Users get wrong Access Level when importing users into SP-C Web controller
  • Users get wrong Access Level when importing users into SP-C Web controller
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
  • AdamSteele
    AdamSteele
Commander JonGreen Commander
‎2020-05-12 06:00 AM
Last Updated: Guinan AdamSteele Guinan ‎2020-05-19 10:14 PM
If you import Users via a CSV with multiple Access Levels, some of the Users can have the wrong Access Level attached to their profile.
Security Expert
Security Expert WEB Controller v4.00 314 I100 and later
The issue seems to occur only if the Access Level with the longer name is read in first, and then the shorter name.
Example: "Access Level" will come before "Access Level Main"
Within the CSV, sort the CSV by the Access Level column to ensure that the shorter name comes first.
  • EcoStruxure Security Expert
  • JonGreen20
