User access with credentials when Reader Expander in offline mode
  • User access with credentials when Reader Expander in offline mode
  • AdamSteele
    AdamSteele
  • RobertAndriolo
    RobertAndriolo
Guinan AdamSteele Guinan
‎2025-06-04 12:23 AM
Last Updated: Picard RobertAndriolo Picard ‎2025-06-04 04:37 PM
When a Reader Expander is offline from the controller, users with Credential Type-based access are unable to be authenticated.
EcoStruxure Security Expert
  • Security Expert
  • SP-C, SP-AC1, SP-ACX
  • SP-RDM2, SP-MRDM2
Reader Expanders store a limited number of user card records locally, depending on the Offline Operation setting. However, user credentials (such as credential types, biometric or PIN-based data) are stored only in the controller, not in the Reader Expander.
It’s important to note that the term "card" in the Offline Operation feature (as described in the online help and the SX-SRVR Security Expert - Operator Reference Guide) refers specifically to the Card Numbers section [1] of a user record, not the Credentials section [2].
User recordUser record
The Offline Operation functionality of Reader Expanders supports authentication using Card Numbers only. It does not support authentication using Credential Types when the expander is offline.
  • EcoStruxure Security Expert
  • AdamSteele25
100% helpful (1/1)
