Upgrading an SP-C-WEB to an SP-C in the field
  • Upgrading an SP-C-WEB to an SP-C in the field
  • JohnBoehmer
    JohnBoehmer
  • BillNeville
    BillNeville
  • AdamSteele
    AdamSteele
Captain BillNeville Captain
‎2019-04-26 01:19 PM
Last Updated: Guinan AdamSteele Guinan ‎2020-11-29 06:04 PM
An SP-C-WEB needs to be upgraded.  Can this be done without removing the controller?
Security Expert
  • Security Expert Controller (SP-C)
  • Security Expert WEB Controller (SP-C-WEB)
Due to site expansion, it is necessary to upgrade an SP-C-WEB to an SP-C.
It is not possible to upgrade an SP-C-WEB to an SP-C in the field.
The SP-C-WEB will need to be replaced and re-programmed via Security Expert Server.
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele20
  • BillNeville19
