Understanding the Difference Between XIF and NXE Files in LON Controllers
  • Understanding the Difference Between XIF and NXE Files in LON Controllers
  • PeterLarsen
    PeterLarsen
  • WaynePeters
    WaynePeters
‎2018-09-06 02:40 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 06:57 PM
What is the difference between XIF and NXE files in LON controllers?
TAC Vista, TAC I/A
  • LNS
  • LON Controllers
  • NL220
  • LonMaker
Users working with LON devices may encounter both XIF and NXE files and be unsure of their respective roles and how to use them effectively.
XIF File (External Interface File)
  • Format: Text-based
  • Purpose: Describes the network interface of a LON device
  • Contents:
    • Device type
    • Network variables (NVs)
    • Configuration properties (CPs)
    • Functional blocks
  • Usage: Used by network management tools during device integration
  • Created by: Device manufacturer or LON development tools
  • Editable: Yes (with caution)
Use Case:
Used during integration to map and understand the device’s capabilities.
NXE File (Neuron Executable File)
  • Format: Binary
  • Purpose: Contains the firmware and application logic for a LON device
  • Usage: Used to download or update the device’s application
  • Created by: Development tools like NodeBuilder or LonBuilder
  • Editable: No (compiled code)
Use Case:
Used when deploying or updating the logic on a LON controller.
Comparison Table
Feature XIF File NXE File
Format Text-based Binary
Purpose Describes device interface Contains executable application
Usage Integration and configuration Firmware/application deployment
Editable Yes (with caution) No (compiled code)
Created By Manufacturer or tools NodeBuilder, LonBuilder
Best Practices
  • Ensure the XIF file version matches the corresponding NXE file to avoid integration issues.
  • Avoid manual editing of XIF files unless necessary and fully understood.
  • Maintain version control for both file types to ensure traceability and consistency.
Labels (2)
  • TAC IA Series
Tags (2)
  • 3319
  • PeterLarsen25
0% helpful (0/1)
