Unable to set the time on a SE7000 controller
Select a Country
  • Unable to set the time on a SE7000 controller
  • DavidChild
    DavidChild
  • CraigEl
    CraigEl
‎2018-09-06 10:16 AM
Last Updated: DavidChild Champion ‎2021-01-27 06:10 AM
The documentation shows how to set the CLOCK but the clock fails to work. The controller always displays the Alarm "SetClock" and the time at the default value " Monday" 12:00 AM
EcoStruxure Building Expert, Field Devices
  • SE7000 Room Controller
  • SE8000 Room Controller
The Real Time Clock in the SE7000 uses the 50/60hz AC frequency to operate, if the unit is powered from a DC power source the Real Time Clock will not function and the clock time will always display Monday 12:00.
Power the SE7000 controller from an AC power source if the RTC is required.
Note: SE8000 uses a different RTC chip and can be powered from either AC or DC and the time operates correctly.
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
Tags (2)
  • 13671
  • DavidChild21
