Unable to see Life Safety objects from FireSense BACnet Gateway.
  • Unable to see Life Safety objects from FireSense BACnet Gateway.
  • CraigEl
    CraigEl
  • AdamSteele
    AdamSteele
‎2018-09-06 01:17 PM
Last Updated: Administrator CraigEl Administrator ‎2023-08-10 07:35 PM
3rd party BACnet Gateway can be seen  and points found when performing "send to database" but the Life Safety points do not show up.
Continuum BACnet
Andover Continuum, EcoStruxure Building Operation
We do not currently support the BACnet Life Safety objects with the Andover Continuum or EcoStruxure Building Operation product lines
Use an object that we do support, either an AV (Analog Variable) or MV (Multistate Variable) would probably suffice as long as the 3rd party Gateway can provide this instead of the Life Safety objects.
See our BACnet PICS statements at the link below that show what BACnet objects each of our products support.
https://www.bacnetinternational.net/btl/index.php?m=20
Labels (2)
Tags (2)
  • 6337
  • CraigEllis23
