Unable to create ContinuumDB on new Standalone system using SQL Express. SA password must be a strong password.
  • Unable to create ContinuumDB on new Standalone system using SQL Express. SA password must be a strong password.
  • CraigEl
    CraigEl
  • AdamSteele
    AdamSteele
‎2018-09-10 03:40 AM
Last Updated: Administrator CraigEl Administrator ‎2022-11-14 05:48 PM
Pop-up error message displayed when trying to create ContinuumDB on stand-alone system. Unable to get past this to create the database.
Error message similar to below:
"Microsoft SQL Server 2005 Setup
The sa password must meet SQL Server password policy requirement. For strong password guidelines, see Authentication Mode, in SQL Server Books Online."
Andover Continuum
  • Continuum Stand-alone
  • SQL Express
When SQLExpress was installed a "strong" SA password was not defined.
As per Microsoft SQL password policy Strong passwords must meet the following guidelines:
  • The password does not contain the account name of the user.
  • The password is at least eight characters long.
  • The password contains characters from three of the following four categories:
    • Latin uppercase letters (A through Z)
    • Latin lowercase letters (a through z)
    • Base 10 digits (0 through 9)
    • Non-alphanumeric characters such as: exclamation point (!), dollar sign ($), number sign (#), or percent (%).
Passwords can be up to 128 characters long. Use passwords that are as long and complex as possible.
To change the SQL password:
  1. Download and install management studio express.
    http://www.microsoft.com/download/en/details.aspx?id=8961
  2. Change SA password so that it now complies as a strong password.
    1. Find the SA user under Security\Logins.
    2. Change the Password.
  3. Run Database Initialization again and create the new database using this new SA password.
Tags (2)
  • 6255
  • CraigEllis22
