Unable to copy SE7000/8000 Configuration to a new Room Controller
  • Unable to copy SE7000/8000 Configuration to a new Room Controller
  • JonGreen
    JonGreen
  • Ramaaly
    Ramaaly
  • PatrickDumas
    PatrickDumas
Lt. Commander Ramaaly Lt. Commander
‎2022-04-06 09:40 AM
The room controller is replaced on-site, and you need to copy the same configuration of the faulty Controller.
EcoStruxure Building Operation, EcoStruxure Building Expert
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE8000
  • SSL SE7000
The wrong file format might have been used
This Video explains detailed steps to copy the configuration to a new or a replacement controller:
[video]
Please note that the older controller will probably have an older firmware version, and thus, you might have to downgrade the new controller to the same version. Also, note you can’t downgrade to below 2.0.0. If the older controller has a version before 2.0.0, this solution will not work and will have to configure the new one manually.
Only After the configuration has been transferred successfully you can upgrade the controller to a new firmware version.
Labels (2)
  • EcoStruxure Building Expert
Tags (2)
  • PatrickDumas22
  • RamaAly22
