Unable to connect to a Simple XML Web Service
  • Unable to connect to a Simple XML Web Service
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
‎2018-09-10 12:43 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 09:03 PM
When adding a Simple XML Web Service interface in to SmartStruxure, the following error message is given.
  • SmartStruxure Workstation
  • SmartStruxure Web Service Interface
  • Enterprise Server
  • Automation Server
  • Automation Server Premium
The (403) Forbidden error means that the destination of the XML address being used is denying access.
Follow these steps:
  1. Verify that the XML address can be reached in a normal web browser.
  2. Contact the provider of the XML web service to gather more information on their requirements.
Note: Some providers require a username and password to acquire their information. In other cases they may require that the HTTP request contain an user-agent header. For example, weather.gov requires the HTTP header and will block any request without it. SmartStruxure does not currently support the HTTP user-agent header. You can check out the Community post SBO - Web Service through a Proxy, JSON and Image conversion as a possible workaround for these situations.
Tags (5)
  • 19064
  • problem
  • remote
  • response
  • returned
