Unable to Access Access Expert after converting to V3
  • Unable to Access Access Expert after converting to V3
  • Ramaaly
    Ramaaly
  • JonGreen
    JonGreen
Lt. Commander Ramaaly Lt. Commander
‎2022-12-12 06:58 AM
Last Updated: Commander JonGreen Commander ‎2022-12-13 06:36 AM
Unable to Access Access Expert after converting from V2 to V3
EcoStruxure Access Expert
  • Access Expert Hosted software V3
Used the same Password as V2
When a site is converted from V2 to V3, Feenics sends out an email with a new username and password that can only be used within AX Version 3.
*Note*
These new credentials cannot be used in V2. Once the conversion to V3 occurs, the V2 instance will be retired and you will only be able to use the V3 AX client to access your instance.
  • EcoStruxure Access Expert
Tags (2)
  • Ramaaly2022
  • Schlage PID
