Troubleshooting I/NET installations and upgrades on multiple client workstations.
  • Troubleshooting I/NET installations and upgrades on multiple client workstations.
  • RobertAndriolo
    RobertAndriolo
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:08 PM
Last Updated: Picard RobertAndriolo Picard ‎2022-11-07 06:53 PM
TAC I/NET
I/NET Seven Multi-workstation Site
Options to investigate when unable to install I/NET Software on some PCs
Difficulty loading I/NET Software onto a PC where the site has several PCs, and the software will load on one and not the other hardware.
The steps below are intended to be used as a checklist and Compare the differences between working and non-working PCs:
  1. Is the memory the same?
  2. Is the OS the same or different?
  3. Is the OS Configured the same?
  4. Does it meet the minimum requirement for I/Net and its applications? TCON298
  5. What are the permissions for the Logged in User?
  6. Does the user have full Admin-Rights to perform the applicable installation?
  7. Is I/Net being installed for the first time, or is it an upgrade?
  8. At what point during the installation does it fail on one versus the other?
  9. Are any error logs being generated during the process?
  10. Can any other software be installed?
  11. Are there any previously loaded applications using a SQL/MSDE DataBase?
  12. Has the IP/network/domain status changed?
Going through the above steps will help rule out some possibilities.
  • TAC INET
Tags (2)
  • 1867
  • RobertAndriolo22
