Transferring Security Expert licenses from one PC to another
  • Transferring Security Expert licenses from one PC to another
  • AdamSteele
    AdamSteele
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 07:37 AM
Last Updated: Guinan AdamSteele Guinan ‎2025-07-06 06:03 PM
Can licenses be transferred in Security Expert?
EcoStruxure Security Expert
Security Expert
Unsure if a single SSN can be authenticated on multiple PC's or if licenses can be transferred or moved.
Each PC requires a separate SSN. These licenses can be transferred between PC's.
  • As part of the licensing process, the hardware details of the computer are recorded against each SSN, so any hardware changes require re-licensing, this also means SSN's cannot be shared across computers, and if used on a virtual machine – it must be assigned a static MAC address.
  • Licenses can be transferred between machines without issue, Product Support will add a registration onto the license and clear the hardware profile after receiving a request. The installer will then do a License Update from the Security Expert server.
  • EcoStruxure Security Expert
Tags (6)
  • 19243
  • AdamSteele19
  • AdamSteele21
  • AdamSteele22
  • AdamSteele23
  • AdamSteele25
67% helpful (2/3)
