Totally remove the existing program from an ASC
  • Totally remove the existing program from an ASC
  • Tom_Poovey
    Tom_Poovey
  • CraigEl
    CraigEl
‎2018-09-10 02:11 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 04:34 PM
TAC INET
  • I/NET Seven
  • All ASC Controllers
If an ASC is not working correctly, it may be necessary to replace the existing program and start over with a new database.
  1. Perform a memory clear on the ASC. See Reset the memory in an ASC Controller for detailed instructions.
  2. Reload the BIN files (UPD) to the controller. This is done by doing an ASC Update function in the I/NET editor
  3. Once the BIN files are loaded, bring the Points up to the Host PC. This is done by doing a MCI Update function in the I/NET editor
  • TAC INET
  • 5709
