There is no way to view the personnel records stored in a NetController
Select a Country
  • There is no way to view the personnel records stored in a NetController
  • Alan_Wood
    Alan_Wood
  • sesa116827
    sesa116827
  • AbeMeran
    AbeMeran
‎2018-09-06 12:44 PM
Last Updated: RobertAndriolo Champion ‎2023-07-31 09:47 PM
Is there a way to see what personnel objects are in the Netcontroller?
Also, there is no way to send the personnel records (or area objects) from the controller into the SQL DB. Doing a 'Send to database' will NOT send personnel records or area objects.
Andover Continuum
All Access Controllers
Viewing personnel records
There is no way to view the personnel records stored in a NetController.
  1. Check to see if the personnel record has been distributed to the controller using the Access Distribution View filtered by the controller.
  2. Set to the controller's ACCNet Id for local validation only.
  3. Use the AccessServer system variable on the controller (accnetid found in the controller's config page) and set it to the Accnetid of the controller, not a Workstation or the Primary Access Server (typically in the 191-254 range). Doing this specifies that the system looks only at the controller's internal database.
  4. If a cardholder can get 'valid access' to a door (associated with a specific controller) and local validation is used, then the cardholder record is in the controller's local database.
  5. If the cardholder can only get 'valid access' when a workstation accnetid is set for the AccessSystem variable in the controller, then the cardholder has not been distributed to the controller.
Tags (5)
  • 7230
  • AlanWood23
  • cardholder
  • controller database
  • local validation
