The OCC output on the SC3514E5045 Line Voltage Swithing Relay Pack Controller will not fire the attached relay.
  • The OCC output on the SC3514E5045 Line Voltage Swithing Relay Pack Controller will not fire the attached relay.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:28 AM
The Occ Output on the SC3514E5045 will not fire a 7 volt relay.
SC3514E5045
The documentation for the SC3514E5045 is incorrect.
Wire the negative of the relay coil to the Occ output and the positive side to +7vdc.
  • EcoStruxure Building Expert
  • 16562
