TGML Webstation graphic text and values are not correctly aligned
  • TGML Webstation graphic text and values are not correctly aligned
  • CraigEl
    CraigEl
  • Benji
    Benji
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-11 09:08 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-11 08:22 PM
When viewing a TGML graphic from Webstation the text and values are not aligned correctly. In Workstation the text and values are aligned fine.
StruxureWare Building Operation 1.5
In the Control Panel\Appearance and Personalization\Display it is possible to change the size of text and other items on your screen.
If this is set  to larger than 100% the text and Values will not be aligned in in the TGML graphic in Webstation.
Set the value for Control Panel\Appearance and Personalization\Display to 100% and not more.
Windows 10
  1. Right click or press and hold on your desktop, click/tap on Display settings.
  2. Click/tap on Display on the left side.
  3. If you have more than one display connected to your PC, then select a display at the top on the right side that you want to change the DPI of.
  4. Under "Change the size of text, apps, and other items", select the DPI percentage and set it to 100% and not more.
Windows 7
  1. Open Control Panel
  2. Open Appearance and Personalization
  3. Set Display to 100% and not more
  • 16879
