TAC Xenta servers are going offline in TAC Vista
  • TAC Xenta servers are going offline in TAC Vista
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
  • HenrikTarpgaard
    HenrikTarpgaard
  • RobertAndriolo
    RobertAndriolo
Janeway Jonas_Brissman Janeway
‎2019-11-26 12:48 PM
Last Updated: Picard RobertAndriolo Picard ‎2022-02-28 02:50 PM
Windows update KB4519976 causes all Xenta servers to go offline in TAC Vista every few minutes.
TAC Vista
  • TAC Vista Server
  • Microsoft Windows 7 or Microsoft Windows 2008 Server
  • Xenta 500
  • Xenta 700
  • Xenta 900
After the Windows update, KB4519976 is installed, the SSL handshake behavior is changed. This affects TAC Vista and its communication with the TAC Xenta server.
There are two workarounds available at the moment.
Solution 1:
Uninstall Windows update KB4519976
Solution 2:
Turn off SSL for the communication between TAC Vista and the TAC Xenta server using the registry setting shown below. This means that only the login will be encrypted when TAC Vista is communicating with the TAC Xenta servers.
  1. Run the utility TacosTweak.exe, located in the program folder where TAC Vista is installed.
  2. Set "Only use SSL for login to TAC Xenta Servers(5xx/7xx)" to 1 to run the communication between TAC Vista and TAC Xenta servers without SSL.
  3. Restart the TAC Vista server for the changes to take effect.
Tags (5)
  • HenrikTarpgaard20
  • JonasBrissman19
  • KB4519976
  • RobertAndriolo22
  • Xenta Servers
100% helpful (4/4)
