TAC Vista database export/import. Description texts are missing when the .zip file is imported.
  • TAC Vista database export/import. Description texts are missing when the .zip file is imported.
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
  • Per_Sjöstrand
    Per_Sjöstrand
‎2018-09-06 02:59 PM
Last Updated: Guinan RobertAndriolo Guinan ‎2022-12-01 04:36 PM
TAC Vista
  • TAC Vista Server
  • TAC Vista Workstation
  • Export/Import
Changes to the object description text fields made in TAC Vista Workstation are not automatically saved in the .mta file.
To make sure that the description texts will be included in a database export (physical structure only):
  1. Edit the Xenta application with text description fields added or modified through Workstation.
  2. Save the Xenta application to the database.
  3. If you do this, the description text will be written in the .mta file and will be included in a database export.
Tags (2)
  • 2555
  • PeterLarsen22
