Supported communications options when running VisiSat software on Windows 7
  • Supported communications options when running VisiSat software on Windows 7
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • Gary
    Gary
‎2018-09-11 06:15 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 08:53 PM
Update to available documentation.
EcoStruxure Building Operation, Satchwell MicroNet
Windows 7 32/64 bit
Clarification of supported communication protocols and devices.
Computer running Windows 7 32bit or 64bit.
Visio software installed must be 32 bit version.
VisiSat runs as a 32 bit application.
SNP
Via computers RS232 communications port.
Via RS232 provided by USB to RS232 converter.
Via RS232 provided by PCMCIA card to RS232 converter.
Via RS232 provided by Express card to RS232 converter.
IP tunneling through Xenta 555/731 AS/AS-P LAN network.
Remote site connection.
NCP
IP tunneling through LAN network.
ARCnet
Via computers RS232 communications port connected through null modem lead to an MicroNet Interface Unit. (MN50-MI-ARC).
Via PCI120U-485 PCI card  (This card was made by Contemporary controls but is no longer). The card was replaced by the USB22 Series. (USB 2.0 to ARCNET adapters) These USB22 adapters do not work with VisiSat.
LON
Not supported with Windows 7 64bit or 32bit.
The latest documentation for VisiSat can be downloaded, see Download latest VisiSat Data Sheets, Engineering Guides, Installation and User Guides, and Release N....
Labels (2)
  • Satchwell MicroNet
  • 14633
