StruxureWare for Building Operation Web Services Limitations
  • StruxureWare for Building Operation Web Services Limitations
‎2018-09-11 01:25 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:05 AM
What are the limitations of Building Operation Web Services?
StruxureWare Building Operation Version 1.3
Due to the XML response rate (XML file information send to Building Operation), it has some limitations.
General Guide in the Technical Reference Guide:
  • The limit for the whole XML response is 100 kb, which includes manually created values.
  • The limit for a string value is 10 kb, which includes manually created values.
  • The maximum number of values created in the Web Server interface is 200.
  • The recommended limit for XML elements in the Web Service interface is 100
  • The recommended number of Web Service interfaces in an Automation Server XML elements at a polling rate of 60 seconds. is 2.
Additional Information:
  • Maximum number of Web Services in an Automation Server
  • Also refer to Architectural Guidelines for your respective version in use.
  • 12649
100% helpful (2/2)
